First of all I would like to thank fenixus for making this possible. His advices were very helpful and straight on. Thanks fenixus. Time to replace rear bank air fuel sensor or O2 sensor (non-CA SPEC) and get rid of that ignoring CEL that robs my gas mileage and power. Was gonna just replace it, but I guess I'll make a DIY for the community and future ref.
Tools:
-Pliers
-10mm socket
-Ratchet wrench
-7/8" SAE Open-Close wrench
First of all let engine warm up and cool down. Next remove the entire intake system to get room to access the rear air fuel/ O2 senor harness, which hide behind & under the intake plenum. Cover throttle body and breather hole if necessary.
Standing behind from driver fender lean and reach your right arm under the intake plenum and unclip the Air fuel Sensor harness. Room is tight but is accessible. I got skinny arms and it was easy to get to. Sorry this is a side-way view of the harness.
Slide your 7/8" SAE wrench down the harness to the Sensor (used the closed end of the wrench). I was able to get away without using the special O2 sensor socket. Turn the sensor lose and get that failing sensor out.
Out with the old, in with the new
Assemble everything back in reverse orders. This is a CA SPEC 1MZ-FE therefor, I need the Air Fuel Ratio Sensor. Non-CA SPEC 1MZ-FE only need the regular O2 Sensor. Parts# for the CA SPEC Air Fuel Ratio Sensor: Denso 234-9007. No more CEL coming on.
Tools:
-Pliers
-10mm socket
-Ratchet wrench
