I just installed my LED bulbs that I had from my 4Runner from LasFit for the blinkers. The 4Runner bulbs were used for the parking lights as well on the front, but they will work just fine for just blinkers too. The rear were just blinkers which matches the Ebay/Amazon link below for them.
Make note, the OEM bulbs are dual filament 7443, some models use only one filament so to be safe just use the 7443.
Tools:
1 - 10mm Socket
1 - Short Extension
1 - Rachet or small impact driver.
1 - Plastic Pry tool
2 - LasFit or Sirius LED bulbs with built in resistors for front.
Purchase from Ebay (offer $10 less and they usually accept).
LasFit 7443 Bulbs - Ebay
or
Amazon Link
1. Open the hatch.
2. Remove the plastic shroud that covers the two 10mm bolts for the taillight.
3. Remove the two top 10mm bolts.
4. Pop the headlight back towards the rear of the car. It will release suddenly with some force. Once removed, be careful to not hit your paint with any sharp edges. The grey socket, twist it counter clockwise to remove it from the housng and pull out.
5. Once out, replace the factory bulb with one of the LED LasFit bulbs from above by pulling it straight out and push in the new one.
6. Once replaced, put it back in the housing, and twist it clockwise to lock. Next put the wiring back in its slot to hold it out of the way on the back of the housing, and then push the housing back into the slot of the car making sure you catch the front plastic hook with the front of the light. It'll snap back in.
7. Put the two 10mm bolts back in and tighten it down. Once complete, Put the shroud cover back on the same way it came off.
Done. Here is a complete picture and video.
Video of them working.
