1 - 11 of 11 Posts
Soylent Green sales
rock crawler
I thought a list of helpful technical threads might be useful.
If you find one add it.
Here's the first one.
22R distributor rebuild
Soylent Green sales
rock crawler
Discussion Starter #2
I've done the power steering on my '83 pickup,heater control valve, entire front end, front calipers lots of photo's; I could write it up if others are interested.
Soylent Green sales
rock crawler
Soylent Green sales
rock crawler
Discussion Starter #6
How to check OBD-I trouble codes
1985-1995 EFI engines do not require a "scanner" to read CEL (Check Engine Light) error codes.
The ECM also does not trigger the CEL every time an error code is set.
Trouble Codes (CEL) on vehicles made before 1996 use the OBD-I (On Board Diagnostics) system, while 1996+ vehicles use the OBD-II system which requires a "scanner" to obtain to obtain the error codes.
All you need is a metal paper clip or small piece of wire. Insert one end each of the paper clip etc. (called the jumper) into the terminals labeled TE1 and E1 in the diagnostic check connector, found under the hood next to the fuse box. Then, you turn the ignition key to on and the CEL will blink in a specific sequence. By counting the blinks, you determine what code you have. First it will blink the first digit of the code. Then there will be a 1.5 second pause, and the second digit of the code will blink. If you had another code, there would be a 2.5 second pause between them and the process would repeat. Then, once all codes have been flashed, there will be a 4.5 second pause, and then the entire series will start over from the beginning. For example, if _ represents a pause and * represents a blink, code 12 and code 42 would look like this if they cycled around twice:
*_**_ _****_**_ _ _ _*_**_ _****_**
Here is a link to the procedure to check the codes manually, as well as the basic generic code descriptions.
And another link.
Soylent Green sales
rock crawler
Discussion Starter #7
Here's one I found somewhere to fix a loose shifter on the auto trans.
I've seen this question come up a few times.
Various Toyotas
re building rear drum brakes and wheel bearings
I Had a leaking wheel cylinder so I decided to do a total rebuild of the rear breaks and replace the wheel bears while I was at it. Most manuals will give you pretty straight forward directions and the tools are pretty common too. You can get a decent press at your local Harbor freight that will help in removing the wheel bearings.
You can find replacement brake part kits online as well; brake shoes at any of your favorite local auto parts stores plus the wheel cylinders.
I have included photos to show what it looked like before and after and well as during the process.
For metal preservation I used POR-15 products because I have had excellent results with them or, you could use Eastwood products too. I strongly suggest you avoid any primers and spray paints from the box stores such as Rustoleum as they just don't last (IMO).
Remember in any overhaul rebuild preparation is everything.
1 - 11 of 11 Posts
