1 - 20 of 49 Posts
· Lives For The Curves
93 Camry
I figured I'd do something useful, so here's a DIY on changing the front brake pads on a Gen3 V6.
Before work: Apply e-brake, jack up frontend, support it with jackstands, remove the wheels, all that common sense stuff. Big tip, only do one side at a time. If you get confused, you can use the other side as a reference to how it should be.
1. Undo the upper caliper mounting bolt. The bolt itself is a 14mm, and you will need to hold the part it screws into still to keep it from spinning with the bolt. I used a small vise-grips because all of our wrenches were too wide to fit in the small space. Apply WD-40 or Liquid Wrench before trying to remove the bolts.
2. Undo the the lower caliper bolt in the same manner as the upper one.
3. The caliper should be free to come off of the mounting bracket now, so remove it. Do not let it hang by the brake hose.
4. Your old pads should pull right out. Place one of your old pads on the inside of the caliper and use a c-clamp or similar tool to push the piston back into the caliper. If you don't do this, the caliper won't fit back on with the new pads. Remove the cap on your master cylinder for this step so that you don't build up pressure when you push all the fluid back into it.
5. Put the new brake pads in where you took the old ones out... pretty easy.
6. Put the caliper back on, bolt it all up just like you took it off, and pump the brakes to get the piston back up to the caliper. Follow the break-in instructions that came with your pads. If none came with them, search online and you should be able to find some. :thumbup: :thumbup:
Here's my old TRD pads... pretty damn worn.
And the old TRDs compared to the new Hawk HPS pads
dont forget to reuse the shims, applying a fresh layer of high temp grease to the back of the new pads. Whenever i do brakes i take a wire brush to the little clips that hold the pads do they can slide back and forth more easily.
If you can, you should have your rotors cut. Toyota rotors are expensive tho - make sure teyre not too thin already.
· Where are we going today?
Camry 00/Corolla 19
yup. what he said
sticky sticky
:clap:
· N/A bites
Paseo
I bought new rotors for $20 each but they are right. Another 2 bolts and the rotors will slide off so you can take them to be cut. Makes a big improvement over just swapping the pads.
Very nice DIY and good pics.
Also mention only do one side at a time so you don't blow the piston out the caliper on the other side.
Nice write-up.
If you take the rotors off to be cut, mark them so you can put them back on the same side they came off of.
I also clean up the clips where the pads go in with some sand paper and then use a little bit of synthetic high temperature disk brake grease at these points before inserting the new pads.
Mike
· The Cool Guy
Toyota Camry 02
ahhh sticky! i always needed a DIY for changing pads. Thanx! i'll change my own pads next time! it'll save me $50!
· Grenaded piston
Actually you want to use disc brake quiet goop on the back of the pads. You can buy it in little packets, a bottle, or spray can.
The high temp grease is for the guide/slider pins.
I also like to clean everything off with brake parts cleaner.
I also recommend having the rotors turned whenever you install new pads.
high temp grease works well in a pinch.
· gen2 kamikaze
'89 Camry V6
what about rear disc brakes? i recently found out (After pulling off the hubcaps), that my car has all-wheel disc brakes. nice! i figured chaniging the brake pads would be really easy, now i just gotta get the pads...and some open-ended wrenches.
peace.
1998 Camry CE
I pinch off the brake hose and opent the bleeder screw as I push the piston back in and drain the old brake fluid out of the caliper.
96 Camry V6 LE
You are supposed to unscrew the bleed valve to let out the fluid pressure when you push the piston back. if you don't, the brake pedal will more than likely feel different than what it should feel. and it is also a very good idea to flush the brake fluid while your at it, since brake fluid is recomended to be flushed every 2 years to extend the brake system's life. and putting brake lube is almost a must so the piston will be able to push the brake pad with an easy and even effort.
1 - 20 of 49 Posts
