1 - 20 of 111 Posts
hx35 turbo camry
1994 camry v6 3.0l
hi tn members!
well this is how i built my custom aluminium cai! NO WELD
i or TN is not responsible if somehow you mess up something or yourself!
first you need these items (i ordered from columbia river mandrel bending)
1 x 2.75" to 3.00" Red Silicone Reducer
$11.49 $11.49 1 x 3.00" Red Silicone Straight Coupler
$5.99 $5.99 1 x 2.50" to 3.00" Red Silicone Reducer
$9.99 $9.99 3 x 3.00" OD, 16 Gauge, Aluminum Straight Tube
$6.75 $20.25 1 x 3.00" Red Silicone 90 Degree Coupler
$16.99 $16.99
1x 1/4npt or 3/8 npt tap (depending on what size hose barb you get)
1x npt hose barb (for the crankcase vent tubing)
-angle grinder with 1/16 cutoff wheel (dont forget to put on hearing, visual and leather gloves when operating and angle grinder with a cutoff wheel! IT CUTS SKIN FAST!!!!)
-sheet of paper
-sharpie marker
-tape measure
-round file or dremel with sandpaper
-3" inlet cone air filter
first lift the driver side of the car and put it on a jackstand! not only a jack!!! use a jackstand!
remove the wheel
remove the 10mm bolts that holds the plastic shield in front of the wheel
peel back the plastic so you have space to work under the fender
i started by removing the 2 10mm bolts that held the big jug in place (one is straight in front of you, the other requires you to remove the shield under the bumper to get to it! (from undersid at the other end of the jug)
pull out the jug and trash it lol
i had to unscrew and rotate away the fender brace that the jug was screwed onto to make room for the big 90* elbow
remove the oem air box (all 10mm bolts)
remove the battery and remove the little duct that goes behind the headlight
then remove the oem intake hose from the throttle body, disconnect the crankcase vent tube and maf and remove the maf (ita a good idea while you have the maf out to spray throttle body cleaner in it to clean it!)
you are now ready to piece together your custom CAI
here is a neat trick to achieve perfect straight cuts with an angle grinder
measure the lenght needed an make a mark with the sharpie, then roll a sheet of paper around the pipe making sure the the overlapping end on the paper are perfectly parralel! then trace around the paper! voila! perfect line! then go real slow with the grinder following the line and you should be able to achieve a real straight cut!
cut the followings lenghts of pipe
7"
13"
and i dont quite remember the lenght of the last little bit of pipe ... was around 4"
take your file or dremel and remove the nasty burrs from your cuts (you can also "sharpen" the end of the pipes so you will have perfect flow! but thats not needed really lol)
take your 7" lenght and drill a 7/16 hole in it (approx 3 inches from an end) then tap with a 1/4 npt tap for your 1/4 npt hose barb. if using a 3/8npt barb then drill a 9/16 hole and tap with a 3/8 npt tap
screw the barb real tight in the pipe then take your dremel or file and remove all the brass from the fitting that is sticking out on the inside
you are now ready to assemble the CAI
this is the order: throttle body --- 2.75" to 3" coupler --- 7" pipe with barb --- 3" coupler --- maf --- 2.5" to 3" coupler --- 13" pipe --- 90* 3" coupler --- little piece or pipe (4") --- 3" inlet filter! DONE!
here you go you just saved a whole lot of money compared to the aem CAI for 1mzfe! :thumbsup:
in these pics i did a really quick polish job using a couple grit sandpapers but next summer i'll remove it and do a real polish job with buff wheels and compound and then i'll powder coat it candy transluscent red!
http://i426.photobucket.com/albums/pp345/lemegacool
/p_00467.jpg
hx35 turbo camry
1994 camry v6 3.0l
Discussion Starter #10
Hi lemegacool,
I'm so impressed, that was just brilliant but it's just that loudness, how about trying to built something less louder as well?
Well you could find a way to hook up the big milk jug to the cai lol that would quiet it down
slowamatic noob
1996 Toyota Camry
great write-up...ok nvm about the prices dealio, I figured it out...:lol:
which kinda cone filter are you using specifically (I know it's 3 inches inlet but where did you get it from) ?? :dunno:
also to quote "cut the followings lenghts of pipe
7"
13"
^ so on the website it states that the 3.00" OD, 16 Gauge, Aluminum Straight Tube are 12 inches in length...how exactly are you cutting it to 13 inches then?? :dunno: =/
hx35 turbo camry
1994 camry v6 3.0l
Discussion Starter #12
7"
13"
lol dont pay attention to prices... i think they all got mixed up lol
hahaha they sell it by the foot so i bought 3 foot came in as a 36" long piece of pipe THEN you can cut it to 13" ;)
filter is "tuned" brand from canadian tire lol
slowamatic noob
1996 Toyota Camry
thanks for the reply...we'll see if they give me 3 separate 1 footers or just a 36 incher... :)
Mad Scientist
94 scepter coupe
glad to see some people stepping up and getting things done :D honestly though i would wrap that thing in some insulation cause the intake air temperature does go up even with that and it's due to the pipe getting heat soaked.
great write up :thumbsup:
1999 Camry
really ?
but the air moves thru the intake so fast. will it have enough time for the heat to be transfered from the heatsoaked pipe into the intake air ?
wrap it w exhaust heat wrap ? haha
hx35 turbo camry
1994 camry v6 3.0l
Discussion Starter #16
my obd2 scanner shows a huge drop in intake temps!!! and i checked when i came back from work and the pipe is ice-cold !!! cant be worse than sucking HOT air from the engine compartment! lol
plus this spring i'm going to powdercoat the whole CAI so it will help insulating...
slowamatic noob
1996 Toyota Camry
did you ever test the temperature with the stock airbox?? if so, how does it compare?? :dunno:
Stock airbox on a gen 4 5SFE is 30 degrees F cooler than with an SRI :thumbsup:
I know, unrelated. But I think it was around 90 degrees F stock and 120-130 degrees F SRI.
hx35 turbo camry
1994 camry v6 3.0l
Discussion Starter #20
No did not test it but im pretty sure its colder with the cai as the oem airbox picks up its air behind the headlight... My cai is under the fender
1 - 20 of 111 Posts
