Here's how to install fog lights on a base model Toyota Camry.
There has been discussion about this before in this thread from 10 years ago:
http://www.toyotanation.com/forum/1...ra-2004-2008/205437-installed-fog-lights.html
I figured I'd share a short video on my fog light upgrade with those who want to add fog lights:
My installation is 100% stock, where I'm plugging into the factory wiring harness, using the factory relay, bumper and turn signal switch. Its all a straight swap, which I picked up for under $80 from my local junkyard.
Since my Camry is American made (TMMK), I swapped the bumper as well instead of drilling my existing one and rigging up support. Luckily gray Camry's aren't hard to come by and I didn't have to paint:
Start by removing the bumper, screws along the bottom:
Screw between fender and bumper:
Three screws along the top:
Bumper is off:
And here's the prewired fog light connector:
Comparison between LE American made and SE/XLE Japan made:
No bracket behind LE:
Mounting points behind SE/XLE:
Fog light mounted and plugged in:
Removed the steering wheel trims and popped off the turn signal switch:
The missing relay at the top is where the fog light goes, BEHIND the fuse box...its difficult to see!
Everything all buttoned down and tested:
For more on the independent fog light mod, see my other video:
The fogs look great, except my HID's kinda over power them:
Hope it helps someone, enjoy the tutorial!
Bumper is off:
