Most of you probably knows how to do it as there are detail posts by Netforcer (dome to pillar to footwell) and CamrySExxx (moonroof map light to footwell).
I kind of did a 'hybrid' of their DIYs.
Because my Camry have no moonroof thus does not have the center light that CamrySExxx has. Was planning on doing it like Netforcer but found I am not as professional/ able as him, taking apart the whole pillar sides etc..
I was lazy and did it the lazy way and it still worked. I might add a fuse holder like touringcamry's trunk CCFL for added safety.
Just to let the newbies know that this DIY is possible even if you are electrical-illiterate like me. (but do read all information/ ask questions before attempting). Especially understand which wire is (+) and (-) and keep them APART at all times. I blew a fuse because the (+) and (-) touched.
DO NOT buy CCFL kits from Logisys!! One of the tube failed within 5 minutes of hooking up
tapping the speaker wires into the dome light.
(+) touching the side where the power plug goes for the dome light, (-) goes to the other side
driver-side
passenger-side: need to take off this black piece, just unclip it at three spots
wiring under the driver-side carpet
The CCFLs still worked during final testing.
Then after putting them in position the driver-side tube went dim (crappy quality white wires!)
driver-side CCFL is ON (photo without flash)
passenger-side ON (photo without flash)
Final product: Front and Back (photo without flash)
driver-side
