OMG WOW! There are DYI on this...but
dpanda88
First you'll have to pop out the black plastic thing around your gear shifter. Then i believe if i remember correctly..there should be some screws holding in the gear selector thing [ PRND2L ] once you pull that out, you should be able to access the light blubs which are 74.
TO everyone else
THOSE WHO HAVE A GEN4 CAMRY THE CLUSTER GAUGES...THERE ARE 5 BULBS SIZE 194 WHICH CHANGE THE WHOLE CLUSTER NEEDLES AND BACKGROUND OF THE CLUSTER. UNLESS YOU HAVE REVERSE GLOW GAUGES...ONE YOU CHANGE THESE BULBS IT'LL CHANGE THE COLOR OF THE NEEDLES. THE CLIMATE CONTROL LIGHTS ARE SIZE 74. TO GET ACCESS TO
THIS...
1-POP OUT THE BREZEL
2-REMOVE THE THREE KNOBS FROM THE A/C UNIT AND THE INSIDE/OUTSIDE SELECTOR KNOB SHOULD COME OFF TOO
3-THERE SHOULD BE TWO SCREWS TAKE THESE OUT
4-REMOVE THE FOUR SCREWS HOLDING IN THE UNIT
NOW THE UNIT SHOULD BE LOOSE
5-THERE SHOULD BE TOO CLIPS HOLDING THE FRONT OF THE A/C UNIT PULL THOSE CLIPS OUT AND NOW YOU CAN GET ACCESS TO THESE 74 SIZE BLUBS
To get these size LEDs go can go to ebay and type in 194 led or 74 led also www.superbrightleds.com [ i believe thats the website ] also has but be sure your getting the right size bulb...theres a website that gives you the listing of the size bulbs for any car. i forgot it though
The only bulb i have no clue what size it is, is the bulbs that go for the "a/c" "defroster" button..i broke both of mine
dpanda88
TO everyone else
THIS...
