1 - 20 of 41 Posts
now I do not have pics of this step but i had to remove the panel that houses the vents and 4 way hazard switch as well as the besel from around my radio I am not sure if this has to happen with the stock radio
next remove the storage compartment and dissconnect the 12 V accessory port
folowed by the panel for the airbag lights as well as the security light and remove electrical connectors
next grab the hvac Panel and pull it twords you to and you can gain access to the back of the unit to dissconnect the components
before removing the connectors i made sure all the knobs were turned far left for less confusion of switch position there are little tabs located on the side of the blend door control as well as temp control knobs press them in and remove from the HVAC head unit as well as the three electrical connectors
Discussion Starter #6 (Edited)
you can now remove the HVAC head unit from the vehicle
flip the head unit over and you can see where the bulbs are that need to be replaced these are bulbs with bulb condoms on them and not leds you can get them out with a small flat blade screwdriver simply twist and out they come
Discussion Starter #7
when they are out they look like this make note that if you want white lights for your controls just remove the yellow condom
Discussion Starter #8
Now on the back of the head unit there are little white tabs that lock the switches into the faceplate gently pry the black housing back to release the clips it is the same on all 3 switches
Discussion Starter #11
ok now for the switch dissassembly flip the switch over and just like when you removed the switches from the face plate pry the white housing out to release the black clips and gently and slowly lift the inside of the switch up and out of its housing
Discussion Starter #12 (Edited)
ok now wiggle the push buttons off the switch and you will see the led burried under it
now gently pry the clips loose to seperate the control knob even further and seperate
Discussion Starter #13
when the switch is fully apart you will see a white gear with a notch in it please make sure you pay attention to where this notch is it must line up correctly or you can damage your component it is lined up with a little nipple on the inside of the switch itelf on mine
Discussion Starter #14
next seperate the blower motor switch just like you did the other two the button comes off the same way the only reason i am posting this one seperat is becaust the internals are different
Discussion Starter #16 (Edited)
OK........................ now all you need to do is replace the bulbs that get snaped into place with these ones from onzium.com or other retail shop you will need 3 for the head unit illumination
http://www.oznium.com/corvette-c5-led
and you will need three of these 3 mm LEDs in the color of your choice
http://www.oznium.com/led
Please note that the 3 MM LEDs and the C5 LEDs work just like Diods so if you but them in backwards they will not light up so please check your soldering work and connections with the switches dissconnected and apart to save yourself some heartach you can just plu them into the vehicle and test them before reassembling them now that you have done that and all works properly reassemble the switches carefully and confirm proper operation and full range of motion and reinstall in the vehicle
Discussion Starter #17
now for the airbag lights and the seat belt light for the passanger seat if you have done the Cluster already it is the same exact thing just swap out the LEDs with the PLCC-2 surfacemount LEDs and you are good to go
Boy Wonder
Did you figure out the steering wheel controls and the door panel yet? Not rushing or anything, I'd just like to have a full parts list so I can order all these lights at once. Then I can do the DIYs as you post them.
And thanks in advance for this and any other DIYs you post. A lot of people have been waiting for a guide for these led replacements but the people who have done it have never explained how to do so.
1 - 20 of 41 Posts
