1 - 5 of 5 Posts
Look in sig
Okay, so this is probably my most quickest DIY....
I'll be posting a bit more as I go along and do things to my Cressida.
My Driver side door lock trim around the door lock indicator cracked and it was ...well not really fixable. I tried super glue but that only lasted so long. I was lucky enough to find that Toyota should still have these pieces available to purchase. These door lock collar tends to crack on the thinest part first - the top part where it is exposed to the sun.
In my case, my interior was Maroon. 1987 Model.
Nothing special. You just slide it right in and it should stay in place. I didn't have to take the door panel off.
Part numbers are as below
FRONT & REAR
Maroon : 67785-22030-02
Dark Blue : 67785-22030-03
Gray : 67785-22030-13
Beige : 67785-22030-15
Toyota Collector
I'm amazed that part is still available. Maroon is a UV magnet for some reason, every Toyota I've seen with that colour interior has terrible sun damage.
Look in sig
Yea, I was too. So I bought a bunch...might buy more....
Look in sig
Still have not seen an MX73 in the yard to grab you the glass trim clips.
Thanks for being on the look out.
Roman was able to find a replacement P/N apparently.
Fastener Windshield - Toyota (75548-22101)
Seems to do the trick. This is for the front/rear chrome longer piece trim. The elbow ones are held in place from the other piece of trim IIRC.
1 - 5 of 5 Posts
