1 - 3 of 3 Posts
They are as separate threads in the read me sticky, along with so many other diys.
http://www.toyotanation.com/forum/1...-throttle-cleaning-gen-5-gen-5-5-gen-6-a.html
http://www.toyotanation.com/forum/1...6-2azfe-camry-pcv-valve-replacement-pics.html
http://www.toyotanation.com/forum/1...02-2011-camry-maf-sensor-cleaning-w-pics.html
http://www.toyotanation.com/forum/155-2nd-generation-2000-2004/1407898-diy-iac-cleaning-situ.html
For IAC, I know there are separate threads in other camry sub-forums here (maybe 3rd gen?). Having done in honda and toyota now just never had to look them up again. You can just take a look and then do more than one of these at the same time.
When I do the IAC or TB, I just clean the MAF and leave it to dry while working on the others...
· Super Moderator
2005 Corolla CE
There is no IAC on Gen 5+ Camry models.
For the TB cleaning, follow the I4 DIY listed above and just account for the different in intake tube design (there is no spring clamp, rather it uses a 10mm bolt). The cleaning is identical otherwise.
1 - 3 of 3 Posts
