I ordered mine from Amazon, have the 3/8" Cr-Mo version here.Thanks, where can I find the Astro Pneumatics at the best price?
Lol I am trying to get the axle nuts off my dads 2004 Camry to replace the hubs and bearings and they won’t come off with a breaker bar so I went out and bought an impact for home since it is not driveable since the bearings completely failed because he kept driving it with the noise so I sprayed tons of PB Blaster on it and went out and bought a 30mm 12 point socket for it to have at home and am hoping to get it off when I get off work it is really seized on there the last shop put it on with an impact and tightened it all the way down with it so it is pretty tight I am sure.I seem to think I recently used a 1 3/8 inch SAE socket recently aka 35mm but I changed a total of 7 wheel bearings on a 2003 Camry, 2007 Camry and 2008 Saturn Aura combination of fronts and rears. Sadly I did those over about a 10 day span total over a 2 week time frame. So I do not recall which of the above used that! LOL I know a 32 would not do it because I carry a up to 32mm in my all metric handy dandy trunk tool box in my 2003 Camry and I had to actually go to my upright rolling tool cabinet and crack open the drawer with the big boy tools that mostly collect dust. My 2003 Camry was made in Japan and is a 5spd manual transmission but the 2007 is North American made and an automatic both have 2AZFE engines. P.S. My 1995.5 Tacoma still has it's original bearings front and rear.
What I did was got a Harbor Freight Earthquake impact 1/2 drive today used the 30mm 12 point socket since the axle nut is 12 point and it took it off with no issues it is rated with a breakaway torque of 1190ft pounds and then it helped on some of the other bolts alsoIf the Axle nut is frozen on, you should use a 6 point socket, more surface area contacts the fastener -> equals more torque to remove. If no good, suggest finding a local shop w/ heat (torch), and equipment to remove / reinstall to proper torque for you to complete the repair later.
Sorry, my bad - I keep forgetting there are 12 pt axle nuts for the Camry. Cool that it zipped off w/o any fuss.What I did was got a Harbor Freight Earthquake impact 1/2 drive today used the 30mm 12 point socket since the axle nut is 12 point and it took it off with no issues it is rated with a breakaway torque of 1190ft pounds and then it helped on some of the other bolts also
I got the air impact it’s the Earthquake XTSorry, my bad - I keep forgetting there are 12 pt axle nuts for the Camry. Cool that it zipped off w/o any fuss.
Did you get the air, or the electric HF Earthquake XT impact?
Asking because it sounds like a torque monster: and the (circa 1990's) Craftsman 1/2" air impact gun I have here is old, and getting tired (like the owner, lol.).
Yeah I tried to break the axle nut loose with a breaker bar and it was flexing so I tried my smaller 1/2 air impact it didn’t even move it so I bought this one and I’m keeping it. The Earthquake impacts have been recommended to me several times by other mechanics also and now I am happy I got it.Air power is still the way to go besides having a huge breaker bar.
Thanks much for the pic (with the model #) AutoMechanic ! ... I see a trip to HF in my near future.I got the air impact it’s the Earthquake XT
That is cool! Much appreciate that info also Camreeeee, will take a look at that also. If it handled those rear knuckle bolts: then it really is the real deal: been there, done that also. They're a PITA....
I just think it's super cool that a portable electric impact has that much torque.
I bet you will love it when you get itThanks much for the pic (with the model #) AutoMechanic ! ... I see a trip to HF in my near future.
... '00 Camry here is due for control arm bushings, a complete rear suspension rebuild, and a replacement steering rack - I'm thinking a new Impact will save me some time & grief when I do the service(s) in the next few weeks.
I would recommend using whiteline poly bushings for the steering rack sleeved bushing even if you don't drive it hard, it will tighten up the steering with worn steering components more than brand new tie rods and a rack with new oem bushings. The rubber bushing allows a 1/4-3/8ths inch of play, 1/2" when shot. The poly bushings don't allow any movement worth measuring without a caliper. Once you put the rack in it will be a PITA if you change your mind.... '00 Camry here is due for control arm bushings, a complete rear suspension rebuild, and a replacement steering rack - I'm thinking a new Impact will save me some time & grief when I do the service(s) in the next few weeks.
Keep in mind they are much harder than rubber, those two I mentioned are the two major bushings that will improve steering feel and response without adding harshness.Thanks for the recommendation on Whiteline poly bushings, and the detailed procedure for the steering rack w/ the swivel sockets and u-joints: that's some Pro tips in the procedure: I appreciate it, the detailed info will save me time here.
I wasn't planning on using poly bushings .. but you've convinced me. Seeing as this will be the last suspension service: I can show the Camry some love this time around. I'll be getting some Whiteline bushing sets (Front,Rear,Rack) ordered this weekend.
I mainly use Snap-on as I am a professional. For the home user HF should work fine. Generally impact sockets are slightly thicker and may pose a clearance issue. Otherwise you should have no problem with them. As far as using 3/8 over 1/2, it depends on what you're using them for. I realize that people here like to tinker with their vehicles but that's becoming harder and harder with the advent of ADAS systems etc. Don't overspend on tools unless you plan on becoming a professional someday.Do you use impact sockets mostly for suspension work, or are there other automotive uses?
What do you think about saving money and getting 3/8" drive shallow impact sockets instead of 1/2" drive?
Here's a link in particular:
3/8 in. Drive Metric Impact Socket Set, 8 Piece
Amazing deals on this 8Pc 3/8In Dr Metric Impact Socket Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
I already have a 1/2" to 3/8" impact adapter to use these sockets with a 1/2" drive impact, but a set of thirteen 1/2" is only $20 at Harbor Freight:
1/2 in. Drive Metric Impact Socket Set, 13 Piece
Amazing deals on this 13Pc 1/2In Dr Metric Impact Socket Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Along these lines, what are your thoughts about different brands of impact sockets?
Thanks
I agree I am a professional myself and I use some Harbor Freight stuff but Snap-on and Matco and Mac and SK are usually my go to’s for Tools because some tools at Harbor Freight are absolute junk the sockets though are goodI mainly use Snap-on as I am a professional. For the home user HF should work fine. Generally impact sockets are slightly thicker and may pose a clearance issue. Otherwise you should have no problem with them. As far as using 3/8 over 1/2, it depends on what you're using them for. I realize that people here like to tinker with their vehicles but that's becoming harder and harder with the advent of ADAS systems etc. Don't overspend on tools unless you plan on becoming a professional someday.
A press is always helpful and the correct method. After removal perhaps a visit to the local shop is in order?You will need to hack-saw a slice out of it to remove tension but not into the control arm and then you can hammer it out with a chisel or screwdriver, before sanding and lubing the bore to slip the bushings in.
