thanks!
Yeah, to get these buttons right you just gotta do it by feel. Feel for the two buttons and hit the right one for the ECO and left for the gas, so you don't hit the gas cap on accident. Kind of annoying but you get used to it real quick.thanks!![]()
Odd the print on the gas and ECO button doesn't light.Not a big deal but you would think Toyota would have the buttons light up.Cost savings.Yeah, to get these buttons right you just gotta do it by feel. Feel for the two buttons and hit the right one for the ECO and left for the gas, so you don't hit the gas cap on accident. Kind of annoying but you get used to it real quick.
ECO will turn on with or without AC, it will not engage if the system is set to blow onto the windshield.to make sure i am understood correctly - eco mode does not turn on, unless a/c is engaged. regardless of cabin temp settings.
Yes u are correct. Just checked that it does not matter if ac is on or off. ECO can be engaged as long as air mode is not set to blow into windscreen.ECO will turn on with or without AC, it will not engage if the system is set to blow onto the windshield.
The ECO button is not magic, it just loosens the parameters under which the hybrid system will engage (engine stop or EV mode).
Yup!Yes u are correct. Just checked that it does not matter if ac is on or off. ECO can be engaged as long as air mode is not set to blow into windscreen.
