Does anyone have these?
1608 Views 17 Replies 12 Participants Last post by  SJlittlefoot
http://www.newtoyotaparts.com/product/?id=638
link added....
It looks like a new product. They also have a Hyper voltage unit also. I was thinking of getting this and am looking for everyones opinion.
Terry
1 - 18 of 18 Posts
Sorry, I forgot the link. It's been added.
Unless you have a shit load of elecronics in your truck. its a waste of $$$.
looks like voodoo to me. not worth $120 in my opinion.
i don't have any experience with it though, somebody may chime in.
looks likes something you could easily make
Not worth it in my opinion... If you were building a performance vehicle, then maybe... I've seen write ups in the import magazines where they installed these... They do increase the HP sometimes, but they also noted that it takes experimentation with each individual vehicle on where each of the new ground points needs to be. They also noted that in some configurations they setup on their test vehicle, that they lost HP. With that said, who really has a dyno they can use to test this out??? Not many people.
Thanks. I always see good advice on many items in this forum.
link added....
Terry
A vague title and a link with no explanation where it goes? That should be great for future searches!
Welcome to Toyota Nation! You're fitting right in!
That's what I thought too - voodoo. But after doing a little googling, I am not so sure.
http://www.caraudiomag.com/testrepo...eports/0401cae_hyper_ground_system/index.html
http://www.4grounding.com/techdata.htm
I was about to edit the title, then I saw the replies I was hoping for. Good information from the more experienced Taco owners.
As long as you're happy.
can do it for a lot cheaper, and its not a big deal unless you have a lot of electronics (e.g. audio) running in the truck. in my case, i upgraded the alternator and chassis ground from my battery to 0awg cable to match the power cable i have running back to my audio amplifiers
Yeah, rip-off. I did this with 0/1 awg wire and a 100amp inline fuse for way less than $120.
I have no stereo system, but I run a winch, lihts and an air compressor so I need all the charge I can get.
Like others have said I can see some merit if you had lot's of electronics in your vehicle. An extra ground whether it is needed or not is a good thing. I had a shop work on an old Mustang II (what a very large POS that was!) I was driving way back and afterwards I noticed the clutch was getting stiffer like it suddenly had a heavy spring racing clutch in it. Nope, my ground strap from engine to frame/body was left off and the engine was grounding through the clutch cable! The stiffness was me breaking the arc welds it was making inside the clutch cable shroud! :)
Awesome.
I had a hot wire for a stereo come loose under the dash of my Tempo once and pinched it in half with the clutch. Yep, the car burned up, lol.
waste of $, even if you have massive electronics you can make one yourself, look at PB's set-up. You see a bunch of them selling on ebay as "grounding kits". Quite a bit of people it seems have bought into that baloney.
1 - 18 of 18 Posts
