Im doing the same thng right now. For the carpet if you want to go with cut pile the best deal if from www.autocarpetoriginals.com they will make you the color you want with the rubber mastic backing for sound insulation. It costs 178 plus loke 20 bucks for shipping. If you want a more plusher carpet it is called truvette. It is the same carpeting that is used in corvettes. That will run you like 267 plus 20 bucks shipping. Now is also a good time to mat the car for sound dampening from road noise and helps the sound system. For the best deal on mat use raammat60. As good as dynamat extreme and alot cheaper. He is selling it for like 79 bucks for 65sq ft of it. Two rolls should do it. Rick from raamaudio also sells ensulite padding-helps with the noise reduction. As well as spray adhesive for the ensulite. Check out this link http://www.cureline.net/lex/raamsale.htm
Let me know if you find anything about a headliner. I've also thought about redoing my original headliner with charcoal suede.
