Change the regulator and motor as a pair.
When I did it I unplugged the motor from the harness and manually powered it and it worked just as bad. That's how I tested it. The new one has worked perfectly ever since. There cars have crappy window motors from the factory.Before you go through all of the time and hassle of swapping motors and regulators, try just replacing the switch.
This issue with Passenger side front window. If it is an issue with switch, it should work with one of the switch (1- One at driver door, 2-One at Passenger front door). In my case I have the same issue with both switches.Before you go through all of the time and hassle of swapping motors and regulators, try just replacing the switch.
I recently broke my 94 Corolla's power window switch, so I grabbed a junkyard replacement. The window would go down fine but it was going up slowly and in little jumps if it was going up at all.
I swapped in another switch-bank I had pulled and the window is functioning perfectly again.
Check pricing on a motor/regulator vs just a motor, and the answer will be self-explanatory.Why do suggest to change the regulator and motor as a pair? Do you mind, sharing your insights?
Wow, nope, odds on both switches failing are slim.This issue with Passenger side front window. If it is an issue with switch, it should work with one of the switch (1- One at driver door, 2-One at Passenger front door). In my case I have the same issue with both switches.
Do you suggest, both switches need replacement?
Yeah its really not that hard. Even easier if you understand that a DC motor can only have 2 wires. Usually black and red. Funny how that sounds just like a battery. :rofl:Wow, nope, odds on both switches failing are slim.
And I totally get it, most of us have a battery in the car, but I still maintain that few people can pull a part out of their car and correctly attach it to the car battery to test if it's working.
More power to you, zzyzzx, as you seem capable, but I have no real idea how to pull my power window motor out of the door and hook it up to the battery directly. I'd be really surprised if more than a handful of people here can too.
Shall I use this for lift/gear mechanism of regulator? It says, it can be use for automotive/truck."Super Tech General Purpose Grease"
