1 - 9 of 9 Posts
It is time for me to do a drain & fill with my 98 Camry automatic. The car manual has a separate listing for a quantify of ATF for the differential (1.7 qts), and for the transaxle (2.6 qts). Is there a separate drain plug that I need to loosen to drain the differential, or does that all pour out of the drain for the transaxle?
· イリジウム
Is yours 4-cyl with the A140e transmission? If yes then there are two chambers. Recently a member had the diff chamber ran dry and ruined the differential.
See also this DIY on differential fill and drain plugs:
Discussion Starter · #3 ·
Yes, that is the transmission, and it is the 4 cylinder.
Discussion Starter · #5 ·
JohnGD, I also have a 2005 Sienna. I started a similar thread about that vehicle, here:
in case you can answer that one as well.
Regardless, thanks for the info!
· イリジウム
A breaker bar from the top side or an extendable ratchet may help provide better torque on the fill plug. The standard ~7" ratchet sometimes doesn't cut it especially if the plug's been on there for a while. And don't go overboard tightening these. And make sure the socket is fully seated to prevent rounding the plug out.
· イリジウム
Check also many YT videos. The newer U-series are designed correctly, in that they don't use a silly separate diff chamber like the older, more bulletproof A-series.
BTW, for transmissions with dipsticks, I'd suggest checking the ATF level on a few occasions before draining to make sure it's in the HOT range. Then measure what you drained out to put approx the same amount back in to quickly get the level into the ballpark.
The process is similar to the A140e otherwise.
Filter and gasket kit for the 2005 Sienna. Beck/Arnley and Wix are popular items (heart symbol):
Rockauto 5% off discount code:
RockAuto.com Discount Code - Expires October 14, 2022
1 - 9 of 9 Posts
