Went to change the spark plugs on my 1992 Camry and found oil on the wire boots so I guess the valve cover gasket and tube seals should be replaced first. Looking over instructions it looks like it is something I could do with no special tools. It looks like the 4 cylinder 1992 Camry needs a bit of RTV in four corners and two flat spots. Can I use some clear permatex RTV that I happen to have or do I need to use the black, high oil and high temp RTV?
Anything else I should watch out for when replacing these seals and gasket?
