Hi folks, I have a ridiculous problem. It is in the pictures below. After I open the door, the piece that I circled with red stays down. Then, to close the door, I have to lift the handle and lift that piece using something small like a pen or the car key. It happens every now and then.
What is the solution you think? I tried putting some lubricating oil but did not help. Now I consider replacing it, if cheap, but I cannot figure out what is the replacement part. I don't even know what it is called really.
