1 - 10 of 10 Posts
G
Hi,
My Camry (90', 4 cyln.) develped a problem now. The door open warning
light comes on all the way. Previously the warning light is only
affected by the two front doors. I suppose this is the feature by the
original design. The warning light is still on even I press the
button(I think it is pressed by the door) on the body frame. There is
no power lock function for my car. I have the Haynes repair manual but
I still have no clues to repair it. Could you give me some suggestions?
Thank you very much.
G
Discussion Starter · #3 ·
Thank you very much. What's the door jamb?
The dome light operates correctly. I mean the dome light is on when the
door closes, and I put the switch in the position door controls the
dome light.
G
Discussion Starter · #4 ·
I have checked the switch. The driver and the front passenger side
switches are good. The rear two switches are always open. From the
principle, "open" should not cause the warning light on, right?
dome light.
I remember the door ajar warning is effective only for the two front
doors.
My car is a basic model which does not have power lock etc.
accessaries.
Now, what would be the cause for the warning?
G
Discussion Starter · #5 ·
And, the tailgate switch has not been checked. I guess it is correct
because I can see the lamp in the trunk is off by putting off the rear
seat back. The lamp is on when I open the tailgate(trunk).
G
Discussion Starter · #6 ·
Next thing to check would be the wiring bundle that flexes when the
door moves - try wiggling those wires to see if it makes any
difference.
Those wires can develop shorts over time
G
Discussion Starter · #7 ·
> difference.
My car is a basic sedan. There is no electrical switch on the door and
I see no wire going into the door. What I see is a bundle of wire from
the front to the rear inside the driver's side edge. There is a wire up
to the door close switch in the jamb. Your method applies to my car?
I see no difference when I wiggle the wire now.
G
Discussion Starter · #8 ·
Hi,
In order not to discharge because of the warning light, I remove the
door warning light behind the instrumental panel. The interior light
will be on even I close the doors. But, when I put the interior light
switch to on, is not on anymore. I cannot figure out which part the
circuit would be wrong. Could anyone tell me more?
Just without the door warning light, I suppose there is no other
problem to my car. Of course, I should close the doors carefully
everytime.
G
Discussion Starter · #9 ·
[email protected] wrote:
"My car is a basic sedan. There is no electrical switch on the door"
There should be a neoprene covered button type switch in the door jamb
of each door that controls the dome light such that when you have the
dome light set to come on when the doors open, those door switches are
opening and closing the circuit.
Removee the rubber cover, remove the 10mm bolt, remove the switch,
clean and spray with WD-40 wipe dry and reassemble.
That should correct your problem.
G
Discussion Starter · #10 ·
Excuse my English. "No electrical switch" means no power lock door,
power window etc. Indeed, I have not found any wires go into the door.
I have used multimeter having checked the switches in the jamb. The
switches of the two front doors work just as I wish: the connection is
disconnected when it is pressed. The two rear switches are disconnect
always.
1 - 10 of 10 Posts
