I have a door lock problem with my 2003 Camry XLE
When the temperature is above 80F, the electric locks do not unlock (keyfob does not work, the drivers and passenger switch does not work, the key on the passenger side unlocks both front doors and the drivers key unlocks only the drivers door)
Took it to the Toyota dealer. They said I needed a new ECU unit at $3500. Part alone is $2500.
This past winter we found all the locks work well. When the temp is above 80F the problems start.
Any possible solutions other than replacing the ECU?
