I need to replace my U-joints, as they are original factory joints. After 250k miles, they make a small clunking noise. I have the U-joints and am going to replace them this week, but figure that I should also replace the support bearing on the front section of the drive shaft (right in front of the middle U-joints).
While I was under the truck loosening the drive shaft flange bolts, I tried to see how this bearing is installed on the shaft (and removed from the shaft). It was not readily apparent. I took the rockguard/cover off the back end of the shaft. The flange that attaches to the front of the rear U-joint is welded onto the shaft, so it can't slip off the back of the shaft. Is this a mutli-piece bearing or is the shaft a two-piece splined shaft? It is not readily apparent. The metal housing surrounding the bearing appears to be a single piece; indicating that it has to slip of the shaft. It may be easy to figure out once I have the shaft off the truck, but I would like to know what I am in for before I get that far.
P.S. Is there anything that I should know about the U-joints, or is it a standard installation? Since it has been so long, I am tempted to take tha shaft and bearings to an automotive machine shop (if they still exist around here) and have them press the joints in. The dang truck is so reliable that I am rusty on some of these repairs.
