1 - 5 of 5 Posts
Could you help me?
After changing the battery, the window on the driver's side of my car no longer works and remains stuck in the up position. This is a 2005 Toyota Corolla car.
I have read a few articles that suggest performing a reset with the glass up and down manipulation. But I can't do it since the window is stuck at the top. I noticed that the "auto" light on the control switch flashes if I press for a few seconds and releas. It flashes only when i remove my finger.
Thank you in advance.
How to reset after battery change.
Sent from my SM-G970U1 using Tapatalk
Discussion Starter · #3 ·
Thank you very much for your reply.
I Can't do this procedure because the drivers windows doesn't work manually. It stop in the up position juste after battery replacement.
Administrator
マズダスピード3
I would check the fuse for the power windows. Look in your owners manual. I don't remember the fuse number, but it's tied into other circuits. Headlight and tail lights I believe, but yours is international model, so may be different than US model.
Discussion Starter · #5 ·
I will check. But i think that if it's a fuse problem, It should affect also the other three windows. Because i have this problem only for the driver window.
I find in a wiring diagram in the internet that the four windows have one power fuse of 30A. However, each motor have an internal circuit breaker.
1 - 5 of 5 Posts
