Drivers side window is stuck in the up position. Was working fine that just wouldn't go down one day. Absolutely nothing happens when pressing switch up or down (like motor is not even getting power). Window had been working totally fine before this issue (not running slow, not binding, etc). The 30A Fuse (#13) is good. Before I tear the door apart, I figured I'd ask if anyone else ran into this. Also, I do see there is a power window relay listed on the auto parts supply sites, however, I cannot find where the relay is (it's not in the box in the engine compartment or in the inside fuse box on the drivers side. Anyone have a clue where the window relay is (or if it even exists). I've tried the window reset procedure (i.e. holding the button down for 4 seconds and then up for 4 seconds)... but absolutely nothing happens... no noise, no nothing. Any insight would be most appreciated.
PS... all the other windows work fine.
