1 - 4 of 4 Posts
95 Previa LE
A few weeks ago the forward edge of my driver side window starting lagging behind the rear as it goes up...I often have to pull up on the front and push backward at the same time in order to get it to go up all the way without jamming. I've pulled the door panel and see a slight bend in one of the regulator arms, and it is the arm that attaches to the front. Is that my problem? I just replaced the regulator and motor 2 years ago...arggg
I have replaced mine twice. I was hesitant the second time but wish I had not waited so long as it was cheap and easy and worked perfectly.
95 Previa LE
yes mine was cheap and easy too, and I'm wondering if that's why I need to replace it again only 2 years later. The regular arm somehow bent (cheap, cheap metal) and that is definitely why its malfunctioning.
1 - 4 of 4 Posts
