1 - 11 of 11 Posts
hi every one please can someone help me with my problem
I own a 2015 Camry XLE V6
and my DRL is not working daytime !
but when I turn on the lights or from auto when get dark both the low beam and the DRL works at night
so can some one tell me where can I find the DRL fuse to know if its blown or not
or if anyone else got the the same problem
Captain Camry
Have you gone through the system settings on your stereo to ensure someone didn't disable them? What are the DRLs you are referring to? The true DRLs on this car are the shared high beam bulbs, running at a lower wattage.
the DRL on XLE AND XSE are not dimmer high beam like SE AND LE
the are with turn signal light
as the headlight is full led
286819
Captain Camry
Gotcha, so the lower bumper light. What they used to call the parking light. My car has four light switch positions: Off, auto, parking, full. Do these lights come on when your switch is on the parking mode? That should turn on all lights, except the main low headlights. Have you confirmed you have not disabled DRL in your system settings on your stereo?
Discussion Starter #6
as you said all these exist off auto parking and full all working during parking
yes on the parking mode the DRL and side marker indicator that in the headlight and taillights are working too
And I chek the vehicle system setting also DRL is on there
but during the day and on auto there is no light DRL ?
Per 2008 Toyota Camry (not the same, maybe similar)
  • OFF
    • All lights off
  • AUTO/DRL
    • DRL
      • High beam, low power
    • AUTO
      • LOW BEAM
  • PARKING LIGHTS / SIDE MARKERS
    • Side markers & tail lights
  • LOW BEAM
    • Low beam, side markers, & tail lights
  • PULL FOR HIGH BEAM
    • High beam, high power
  • PUSH FOR HIGH BEAM
TN の がしょう
2015 Camry XSE V6
So you're saying the lower bumper LEDS are not on when in auto mode on the selector?
1 - 11 of 11 Posts
