1 - 20 of 20 Posts
trd04taco
2004 Tacoma 4WD TRD
Do you mean Daytime Running Lights? I've never seen a 95-04 Tacoma that had them before. My truck has all the goodie packages too. What bulbs are illuminated when they're on?
Discussion Starter · #4 ·
Yes, Im refering to Daytime Running Lights. The headlights come on when the truck starts. They shine at about 75% brightness. It refers to them in my owners manual. I like to run Sylvania Silver Stars in my vehicle's, and they only lasted about 9 months because of being on daily.
trd04taco
2004 Tacoma 4WD TRD
Wow, I didn't even know any 95-04 Tacomas had that feature. I knew 4Runners did though. Good luck on the mod.
Toyota considers DRL's an option on most of their products.
The option is often included on vehicles with "Limited" trim packages.
I found out that for 2000 Tacoma's, the DRL option was associated with the anti-lock brake option; they came together as options on units with the top-end trim package.
trd04taco
2004 Tacoma 4WD TRD
Good info :thumbup:
01 & 04 S-Runners
I believe DRL's first appeared as an option bundled with the 4-wheel ABS package in the 2000 model year. If I recall correctly, it remained bundled within the optional ABS package for 2 years, and then became a separate option by itself effective with the 2002 model year.
DRL's were not 'factory' / 'standard' on any US market Tacoma up through 2004.
Silverstars are crap. They burn out way to soon. Try Hella xenon blues; a good quality WHITE light that won't leave you in the dark (premature burnout). I've used both, and can say without a doubt that Hella's are a superior bulb. I have them in my Tacoma and my wife's Civic. Overall a great bulb. (No, I don't work for Hella, just a very satisfied customer!):)
01 & 04 S-Runners
dufremle said:
I have the DRL's but I do not have ABS.
Apparently it *was* possible to get DRL's by themselves (without the ABS package) in 2001. The later 2001 factory spec sheet I have lists DRL's only with the ABS Package. I found an older factory press release which lists the DRL's as a separate option.
There's no such discrepancy in the 2000 model year documentation, though ...
01 & 04 S-Runners
jentzschman said:
I have a 2000 tacoma, is the wire still the white w/ black stripe?
I did not seem to see that wire on mine.... I guess I will need to look a bit closer...
Go to the online 2000 wiring manual documentation at:
http://www.ncttora.com/fsm/2000/index.html
... and check the diagrams for DRL and non-DRL setups.
I have no idea what you're trying to figure out based on the skimpy clues in your post ...
1 - 20 of 20 Posts
