Hey Guys, I recently purchased a brand new drum set for my 7th gen 2001 celica. I've had a mechanic install it and drove out of the shop in perfect working condition. A week later i realize that the Shoes aren't making contact with the drum whatsoever and i'm only really using my front breaks. I go back to the shop and the readjust the shoes to make them make contact with the drum and it worked for a week then exact same issue happened. I've taken it to 2 shops afterwards and they were unsure what the issue was. One said it could be my break line but the other confirmed that my break lines were fine.
Also my hand break does absolutely nothing at this point. I'm driving with the hand break up because it helps with the breaking. If i were to drop the hand break and try to use my breaks then there would be zero contact at the back but when its up and i push the breaks it actually helps a little bit. As if its pulling the shoes further out so when i hit the break it actually makes contact.
I've just spent too much money trying to get it checked out so I'm wondering if any of you have any idea on how to fix it or anything specific i should look at.
