I have a Corolla 2010 XRS and was looking at the DxBT-2 and I had a few questions.
What am I looking at in terms of HP and Torque (aprox is fine)?
What am I looking at in terms of fuel economy?
How will this effect the life of my engine and transmition?
How compatible is this with me car?
Thanks
so thats the descendant turbo kit for the scion xb-2 if i am correct. You need to contact rob at descendant tuning shop @ 310.533.8900, I was going to call him as well about this kit, basically from my understanding it will be a tight fit on our xrs and the side mounted intercooler wont work, so you will have to get a FIC. I think that kit is good for 300 hp, depends on how you tune it.
My suggestion would be to boost only to 200 whp if you are worried about engine life. cause at 250 whp and above your engine will not last upto 200K if thats what you want, specially if you beat on it a lot, the stock internals can only handle so much. auto or 5spd ? 5spd - upgrade clutch (if boosting more than 200 whp, otherwise stock should be fine). Auto - might need a tranny cooler.
if you are boosted, you should not worry about fuel economy, if you beat on it, it will suck, if you baby the throttle well might be ok.
why i say it might be a tight fit is cause I have the afe intake from the xb-2 and I can see the battery bracket mounts holding the heat shield dont line up at all, so you might have some issues with all the piping sitting properly.
Doing this turbo upgrade involves upgrading other components as well, brakes, suspension, tires. So if you are serious about doing it, look at all these things, not just the price of the kit. also include price of tuning. Do your research, talk to rob, good luck and keep us posted.
oh and also you might want to check out scion life, tons and tons of info there on FI.
