1 - 7 of 7 Posts
I have a RAV4 XLE Premium 2019.
The dynamic radar cruise control is accelerating, decelerating by not breaking if the car I am following decelerate by applying a light break. So I have to break manually.
I tried other RAV4, thay all apply a soft break while dynamic cruising.
I scanned the car and it has no fault.
Anyone can help?
2021 Avalon XSE Hybrid
Are you in dynamic or "normal" mode?
When you turn on the cruise, if you tap the button to activate the system, it goes into dynamic mode.
If you press and hold, it will go into old-school mode where it will not self-adjust for the car in front of you.
If it is decelerating, then I'm not sure I understand what the problem is.
It does not maintain spacing behind the car in front of you, or it doesn't slow quickly enough and you are worried that it will hit them?
Discussion Starter · #5 ·
It stops applying gas but it doesn't auto break even i approach the car ahead. I tried it and it was very dangerous, i was 5cm far from the car ahead and it didn't stop
19 Corolla HB SE 6-spd
Anyone can help?
Make sure your Toyota badge in front of hood is clean and clear of snow and ice.
1 - 7 of 7 Posts
