Alright guys, so i went to the dyno today for some runs and tuning and found that my settings on my Apexi S-AFC2 were pretty damn close lol.. anyways we did a couple runs and did some minor adjusting to bring the air fuel mixture to lower and mid 10% while on boost in higher RPM range. The car layed down 159.4hp and 162lbs. tq. to the wheels at around 11psi, the car with stock internals and the stock 9.5:1compression and 8psi layed down 151hp and 152lbs. tq. Some of you might think that im disapointed after all the engine work i did ? but actually im not surprised at all and actually im happy
160hp to the wheels for an auto is about 200hp at the crank and if you guys remember Rippmods shop Camry 5spd at 11psi put down 191hp and 190lbs. tq ? with stiock internals and stock compression. I know i would lose some power with my 8.5:1 compression pistons but i would be able to run more boost safely but if i had the stock compression and 11psi i would probably be making 180hp to the wheels maybe ? but not as safe. We built the motor to handle more boost and handle it safely but im pretty sure i made some power by doing so too because if i had just lowered the compression and nothing else i think i would be making less than 150hp at the wheels with the low compression pistons.
Max torque came in at about 4500rpm and max power came in at6000rpm, air fuel ratio was perfect cruising at around 12 and 13% and when it hits boost it dumps lots of fuel bringing it down to low 10% range. Im pretty sure this just how the Mr3 Turbo MAP sensor works.. when it sees boost it tells the computer to dump fuel to keep it safe. At top end we did notice something weird, the power band would jump up and down at around 5500 - 6000rpm.. we think this might be spark misfiring or getting blown out. I was told to try lessen the gap on my sparkplugs and that should fix that which might help me make more power at top end, im probably gonna go one step colder plugs too. So anyways ! thats my update, its been 2600miles since we got the rebuilt motor up and things are running great, the car feels nuts when i take it up ! it pulls hard ! im gonna drive it around like this for a while, if i had a 5spd trans i probably wouldve boosted it up more but for now 11psi is nice
trans is the next thing if and when it goes out ! let me know what you guys think and ill try answer any questions anyone has
-shook
-shook
