I have a 4cyl and did a 5sp swap
But i used an s54 manual transmission, everything bolted up fine, even used the same axles.
Jason.MZW20 said:You'll use an E153 (90-95 MR2 Turbo or 97-01 Camry/Solara V6, it doesn't matter) clutch disc with the S51/S54 pressure plate and the same flywheel. The V6 flywheel won't bolt up.
Well I was saying the bellhousing on the E153 was changed in 1993 on the MR2T for future use with a V6. The 1997-2001 Camry/Solara E153 is of the same design as the 93+ MR2 turbo except the shifter linkage is at the back of the transmission where you need it to be. Because the design of the transmission is different, and the shifter linkage itself is different, it'd be best to use the 97-01 V6 shifter cables with the E153, instead of your S51 cables, to avoid any shifting difficulty.
