1 - 2 of 2 Posts
I purchased 5000k CREE LED fog light bulbs (H3C) for my '03 V6 Limited Highlander. I am struggling to find an easy way to do this. The passenger side is a little easier through the front opening, however, the driver's side has that hard plastic induction piece blocking access. I feel I'm stuck removing the wheel well which looks to be a PITA with whatever type of rivet plastic is holding the two sections together. Any suggestions?
You do it by any means possible. If you got to remove the wheel to make space, do it. If you gotta pop out plastic clips, do it.
1 - 2 of 2 Posts
