1 - 3 of 3 Posts
My 2000 Echo's A/C didn't blow cold. It turns out the low side pressure was fine, but the compressor wasn't turning. I read somewhere that the A/C compressor's clutch eventually wears down so it doesn't grab the pulley anymore, and that sometimes removing spacers can move the clutch enough to allow it to grab. I took off the bolt on the compressor pulley and the spacer fell off. I put the bolt back on, and now I'm COOL!
:rofl2:
Toyota 87 pickup
Hmmm, interesting... So, you basically are running your clutch without the spacer? Isn't the spacer needed to align the pulley with the belt?
Apparently not. The compressor engages when I turn the A/C on, disengages when I turn it off. No issues. Works like it is supposed to.
1 - 3 of 3 Posts
