Here you go
http://www.amazon.com/Philips-12824...1402262761&sr=8-1&keywords=phillips+daylite+8
One little suggestion on installing, I have noticed that the field of vision seems limited to straight ahead for total brightness, as you move to the side they dim, maybe other brands do also, I don't know.
On my Camry I mounted them so that they conformed with the curve of the bumper cover, maybe set them straight ahead??? I don't know, of course when you diminish one side of your field of vision the other side will improve in the other opposite direction, HUH, does that make sense :dunno:
In other words I would say they have a projection range of approx. 30 degrees straight ahead for full brightness, so its one or the other. They state to not mount them more that 10 degrees off center from straight ahead.
God Now I'm confused, hope it makes sense :facepalm:
They are pretty bright plus I did not hook up the wire to dim them when the headlights are turned on, they are ON WHEN THE MOTOR IS ON, period, the module controls them but the option is there if you want it
NSF
