1 - 1 of 1 Posts
Eibach suspension springs and components are engineered to meet the extreme requirements of racing, from the 245-mph Mulsanne straight of Le Mans to the fender-to-fender combat of the Daytona Motor Speedway.
The chassis of a street vehicle is designed to be built at a minimum cost, and suited for an "average driver". We enthusiasts, however, are anything but average. We know what we want from a vehicle. We want immediate response, reduced body roll, increased stability and enhanced cornering ability. And we want the look that comes with those characteristics---a lower, more muscular, more athletic stance.
The special skills of Eibach engineers are in the tuning of the individual components (springs, shocks and sway bars) to achieve the best possible harmony between the driver, the automobile and the road. As a driver you immediately feel more direct handling and greater predictability. Nose dive under braking is reduced, as well as excessive body roll in hard cornering. In any performance driving situation, tracking stability--and driver confidence--is greatly enhanced. Lowering your vehicle has one more additional benefit that we learned from all the race teams we work with and independent testing: reduced wind resistance. This allows for higher top speeds on the race track and better fuel efficiency on the street! See for yourself: check out how the average car or truck can be transformed with the installation of an Eibach suspension system.
Eibach regards Motorsports as the ideal proving ground. The experience we gain at the highest levels of racing is directly converted into the development of the highest-grade chassis components on the planet. And the enthusiasm created by the challenges of motorsports drives us to ever-higher performance---performance that you will enjoy every time you drive.
Made in Germany and the USA
TOYOTA
Camry - 1996-2001 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4 & 6Cyl MCV20/SXV2 from 11/1996
Camry - 2002-2003 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4 & 6Cyl MCV20/SXV2
Camry - 2004-2006 - Pro-Kit (Performance Lowering Springs - Set of 4) -
Camry - 2007-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) -
Celica - 1989-1999 - Sportline Kit (Extreme Lowering Springs - Set of 4) - GT/ST Coupe including Turbo ST18/ST20 from 10/1989
Celica - 2000-2004 - Anti-Roll Bar Kit - FRONT - GT & GTS from 01/2000
Celica - 2000-2004 - Anti-Roll Bar Kit - FRONT & REAR - GT & GTS from 01/2000
Celica - 2000-2004 - Anti-Roll Bar Kit - REAR - GT & GTS from 01/2000
Corolla - 2003-2008 - Pro-Kit (Performance Lowering Springs - Set of 4) - CE & LE S
Corolla - 2009-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - XRS
Corolla - 2009-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - CE & LE S
Matrix - 2003-2008 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4Cyl
MR2 - 1985-1990 - Pro-Kit (Performance Lowering Springs - Set of 4) - AW11
MR2 - 1991-1995 - Pro-Kit (Performance Lowering Springs - Set of 4) - Inc. Turbo SW20
MR2 - 1991-1995 - Sportline Kit (Extreme Lowering Springs - Set of 4) - Inc. Turbo SW20
MR2 - 2000-2005 - Pro-Kit (Performance Lowering Springs - Set of 4) - Spyder ZZW30 from 05/2000
Prius - 2004-2009 - Pro-Kit (Performance Lowering Springs - Set of 4) - excluding Touring NHW20
Prius - 2010-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - ZVW30
Solara - 1999-2003 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4 & 6Cyl MCV20
Solara - 2004-2008 - Pro-Kit (Performance Lowering Springs - Set of 4) -
Supra - 1986-1992 - Pro-Kit (Performance Lowering Springs - Set of 4) - 6Cyl including Turbo MA70 from 03/1986
Tercel - 1995-1999 - Sportline Kit (Extreme Lowering Springs - Set of 4) - C5
Yaris - 2007-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - Hatchback S Sedan Sedan
SCION
tC - 2005-2010 - Pro-Kit (Performance Lowering Springs - Set of 4) - ANT10
tC - 2005-2010 - Sportline Kit (Extreme Lowering Springs - Set of 4) - ANT10
tC - 2011-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 2.5L 4Cyl AGT20
tC - 2011-2011 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 2.5L 4Cyl AGT20
xA - 2004-2006 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 1.5L 4CYL NCP61
xB - 2004-2006 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 1.5L 4CYL NCP61
xB - 2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 2.4L 4Cyl AZE151
xB - 2008-2011 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 2.4L 4Cyl AZE151
xD - 2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - ZSP110
xD - 2008-2011 - Sportline Kit (Extreme Lowering Springs - Set of 4) - ZSP110
LEXUS
GS300 - 1998-2005 - Pro-Kit (Performance Lowering Springs - Set of 4) - JZS1
GS300 - 2006-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4-door excluding AWD V6
GS350 - 2006-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4-door excluding AWD V6
GS400 - 1998-2000 - Pro-Kit (Performance Lowering Springs - Set of 4) - JZS1
GS430 - 2001-2005 - Pro-Kit (Performance Lowering Springs - Set of 4) - JZS1
GS430 - 2006-2007 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4-door excluding AWD V6
IS250 - 2006-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - RWD 2.5L V6
IS300 - 2001-2005 - Anti-Roll Bar Kit - FRONT - including Sport Cross JCE1
IS300 - 2001-2005 - Anti-Roll Bar Kit - FRONT & REAR - including Sport Cross JCE1
IS300 - 2001-2005 - Anti-Roll Bar Kit - REAR - including Sport Cross JCE1
IS300 - 2001-2005 - Pro-Kit (Performance Lowering Springs - Set of 4) - including Sport Cross JCE1
IS300 - 2001-2005 - Pro-Plus Kit (Pro-Kit Springs & Anti-Roll-Kit Sway Bars) - including Sport Cross JCE1
IS300 - 2001-2005 - Sportline Kit (Extreme Lowering Springs - Set of 4) - including Sport Cross JCE1
IS300 - 2001-2005 - Sport-Plus Kit (Sportline Springs & Anti-Roll-Kit Sway Bars) - including Sport Cross JCE1
IS350 - 2006-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 3.5L V6 2WD
ISF - 2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 5.0L V8
RX330 - 2003-2008 - Sport Utility Kit (Set of 4 Rear Springs) - from 06/2003
RX350 - 2003-2008 - Sport Utility Kit (Set of 4 Rear Springs) - from 06/2003
RX400h - 2003-2008 - Sport Utility Kit (Set of 4 Rear Springs) - from 06/2003
GO TO NOPI EIBACH Catalog for more specific details
Contact the salesmen below or PM me for our best deal on Eibach
1 - 1 of 1 Posts
