Soon after I bought my Gen 2 Cam did I realize how much of a headache it was going to be for me alone to do a custom install. The rear speakers alone really piss me off...that bar! THAT BAR!!...
Anyway, enough tantrums..
Ok so my real problem lies here, my radio and my clock don't work. Neither do my front side corner lights and inside overhead light. My best guess is it is all connected on the same bizarre circuit. I can't figure out what the problem is. Naturally I checked the fuses, the one for "Radio" - 7.5 - was blown, so I replaced it which thereafter blew again. So now on the third fuse here, still no radio. All connected fine it seems, I've checked and reconnected it. Radio is just black and won't even do anything, same with clock. They just died for some reason. I can't figure it out, I've torn apart the entire inside front of the car because it is driving me mad. Nothing is cut wrong, all have wire caps and nothing is cross-wired. Something must be though, because obviously they aren't working.
Everything else works, front lights work, rear lights work, gauge cluster works, A/C etc works.
Any help or ideas to lead me to an answer is much appreciated
Also to include this here instead of double-posting. I tore out the rear carpeted dash, and I was thinking of doing that template thing with MDF or some wood. I was wondering what thickness you guys might suggest in order to raise it up enough to mount some speakers in, or some ideas on what I could do with that.:thumbup:
