HELP ME!!!
I hooked up an underglow kit underneath my 2000 celica GTS. I made sure that I hooked it up correctly, i triple checked. After installing the kit I was ready to give er a shot and when i flipped the switch everything shorted out and my ground wire burned off.
Now my Heater, locks, windows, radio, tachometer, and speedometer won't work AT ALL. No power to any of them. I have checked all fuses and main fuse looks fine. I looked online and found a wiring diagram for the entire car. I dug through it and found all these things are tied into the body ECU.
Where on the body is the body ECU on the 2000 GTS model?And if that isn't the problem is there any other way to fix the problem?
-Thanks for the help
Cheers
Cheers
