On Sun, 31 Dec 2006 10:38:54 -0800, ceralor wrote:
> Hachiroku ãƒ?ãƒ?ãƒã‚¯ wrote:
>> On Sat, 30 Dec 2006 14:45:46 -0800, ceralor wrote:
>> > I have a 1986 4-door Camry with an odd issue concerning the ebrake.
>> > Even if it's off, and drives like it's off, the light will remain on
>> > quite a bit of the driving time, preventing me from using cruise
>> > control. My college commute is over 500 miles, so I almost cheer when
>> > I see the light turn off because I know I can use the cruise control
>> > again. I've checked the brake fluid levels and that seems to be OK.
>> > Does anyone have any suggestions?
>> There is a switch and an adjustment under the e-brake handle. Try
>> adjusting the switch so it makes proper contact, or, as a test, put
>> something between the handle and the switch to make sure it is depressed
>> far enough. If the light stays on, you either need a new switch, or you
>> have bigger fish to fry...
> When I reached in and pushed the switch down all the way, it did the same
> thing that happened when the handle is down from being up -- the light
> merely dims. It gets brighter when the switch is disengaged, IE the
> e-brake being pulled. I guess I should get a new switch? Where could I get
> one, and how much would it cost and/or how would I replace it? I'm
> assuming that housing lifts off.
My Mom's car!
I can give you a better answer in a couple days, but drawing from memory,
open the console, remove whatever you have stuffed into it and look on the
bottom. You should see 2 screws, maybe three. Loosen these. Also, from
near the seat back, look at the sides of the console. There should be one
screw on each side. Move the seats forward and fold them forward and they
should be easily accessible. Now, there may be a couple more, I can't
recall right now. Gently lift up; if you feel resistance, there may be two
screws further forward, or on the sides of the front. The console should
lift out and forwad, exposing the brake mechanism. You should be able to
see the switch. I can't remember if Closed is light off, or Open is licht
off. Remove the connector and see what happens. I believe the light should
be on. Shove a piece of wire or a paper clip into it and try again. One
way or another, the light should be fully OFF. If not, then there is a
problem with the wiring...
or the brake system. My best advice is, during testing, if the light does
NOT go COMPLETELY OFF, take it to a dealer! Hopefully it's wiring, and not
a brake system going kablooey!
BTW, check for pinched wiring. If part of the wire is exposed and
grounding gainst something it's not supposed to, this could cause your
problem.
Good luck!
