Hi. I have a 1994 2WD with the 22RE engine and 52k original miles. it's been great since new, however, I've had a bit of running trouble I need to fix as the truck has failed NJ emissions inspection this weekend.
About 2 years ago the check engine light popped on and coded to the ox sensor as one of the choices. Since then, I've replaced the distributor cap, plugs and rotor and air filter. A local garage has inspected it as well, repairing the small crack in the pipe near the forward ox sensor and doing a few other things. They did not recommend replacing the ox sensor. When the truck failed inspection 2 years ago for the same emission problem, this garage did an injector cleaning and passed it for NJ inpsection.....now I'm back in the same situation, 2 years later.
The engine runs with a bit of hesitation until it gets warm. It did not do this prior to any of the problems or work above, so it seems there is something definitly causing trouble related to performance/emissions.
I'm pretty handy and have tools. Any suggestions would be quite welcome...thanks...Jim.
