The FSM says to plug the vacuum lines for the vacuum advance on my 87 22r to set the timing. One has hardly any vacuum (maybe positive pressure? ) and the other vac line that goes to the vacuum advance has vacuum. If I plug the one that has vacuum the engine dies.
Right now I have the distributor set in the middle of the timing adjustment plate and my timing is at around 8 degrees with the vacuum lines connected OR not since the vacuum advance is not holding vacuum on either port. I just ordered a new distributor a day ago.
It runs good but seems to be using a lot of fuel. I'm trying to make this truck my DD and have seen small plans for this truck (paint,wheels,ect.) but not at the current gas usage.
I recently replaced the HG, water pump, timing chain,oil pump. I moved the chain on accident on the install but the crank keyway and cam timing mark both face up when at tdc.
Before I removed everything the engine temp was about 1\4 up for the short time I've had this truck. Now it's always right under half way all the time. It runs great but uses too much gas. I'm c driving the truck to calculate my mpg's but it's low teens.
