Try removing the thermostat and reconnecting its housing. Then use a hose to flush the block from the coolant intake side on the head. You can also remove a few heater hoses, etc and use the hose to flush them out plus the heater core.
There are coolant flush additives you can use but one issue is any material broken loose from the engine may end up plugging the radiator.
