1 - 7 of 7 Posts
Good afternoon guys,
just a question, please see attached. Is it the idle in my corolla correct? This is with the AC off.
Thank you!
jup , ur idle rpm is perfectly fine. car when fully warm up, the idle at park should be around 750-850 rpm and never exceed 1000 rpm.
On mine, it gets as low as 500-550 RPM with lights off, and reversing the car slowly while steering. It does shake a bit under 600rpm.
09 Corolla Base 17 Camry SE
Mine as well.
have u cleaned the throttle body and iac valve?
Did a few times, at least 4-5 times over the first 100k miles. I will start doing it DIY as I learned over time that I dont really know if what I pay for is being done or just invoiced. If I do it myself, I will know its been done for sure ;)
1 - 7 of 7 Posts
