1 - 3 of 3 Posts
Hi,
My 07 Camry V6 LE engine light went on after I filled up at the local gas station (low fuel light was on for about 2 minutes before I got to a gas station). And, I also forgot to close the fuel door (not gas cap).
Engine light go back on after 15 minutes of driving after I try to clear the computer by disconnect & reconnect the power from battery. And, for the first time since I own the car the engine hesitated (once or twice so far).
Could it be that I have a dirty fuel filter?
Should I buy a OBD II reader before I take it to a mechanic/Toyota dealer?
'07 XLE 4 cyl.
Remove and replace the gas tank fill cap, reset computer by disconnecting battery. If light is still on either read the code (if you are going to do something about it) or take it to the dealer.
Reactions: NoSoup
Discussion Starter · #3 ·
It turn out that my 07 Camry have "PO354 ignition coil D Primary/Secondary circuit malfunction".
I hope that the ignition coil malfunction is under warranty for my car at 26,700 miles.
1 - 3 of 3 Posts
