1 - 6 of 6 Posts
Hey guys, I don't know if this engine noise is new to me or not, I swear I haven't heard it before, here's a video, the noise happens when I turn the key to ACC and then when I turn the car off. The noise happens for a quick second and I cant really tell where its coming from. Does yours do this too? 2015 auto tc here!
01 Avalon XL, 03 Avalon XL
Do you mean the slapping sound around 8 secs? I hear 3 noises, ?door open? @3 sec, slap at 7-8 sec, ?door close? @14 sec.
It sounds like an array of solenoids opening up, then closing down. Is there any aftermarket stuff on the car (alarm, disabler, HID headlights, etc.)?
From 3-5, there's a hum that almost sounds like a stuck motor trying to run. Not on my 01 or 03 Avalons (which are Camrys, 6-cylinder engine) but on our 00 and 04 Tauruses, the secondary air pump ("smog pump") would run on shut-down, then spool down. I have no idea if there's a secondary air pump on the tC
Wikipedia tells me that your gen tC had an optional turbocharger - does you car have this and is it an electric turbo (forgot to ask this above: any aftermarket tuning stuff on it?)
You also seem to have an electric power steering system...
Hey there, no aftermarket anything on this car, no turbocharger, yea I’m lost as to what the noise is and if I may have heard it before, or I just wasn’t paying close attention. I’ve had the car codes run but there’s none. Kinda lost here, no cel.
Well, there's a diagnostic tool called ChassisEAR that has 6 microphones that you locate strategically to pinpoint where sound is coming from. I actually bought a kit for $75 or so from ebay. I was facing a $700 rear strut R&R due to a clunk and I wasn't convinced that the shop was right about the struts. The tool saved me from the strut R&R because the clunk in my car was coming from a rear suspension sway bar bushing, a $17 oem part, or $2-8 on Rock Auto for aftermarket. (Yeah, $700 - I'm old and have to let a shop handle the heavy stuff).
Alternatively, you can cut a length of PVC pipe and use it as a mechanic's stethoscope. Hold one end at an ear and the other on a possible source of sound. You might have to do this for many minutes as someone else does your RUN > ACC > off sequence, with you positioning the business end of the pipe at this or that possible area of sound.
1 - 6 of 6 Posts
