1 - 2 of 2 Posts
2014 Camry Se. 99,221 Miles
I’ve been having this issue with my car making some noise when the ac or heater is on. When I press the gas or make a complete stop it makes this crackling noise (can’t really explain the noise) . I’ve replaced the belt & still does the same noise. Any opinions on what it can be would be greatly appreciated.
You got to be better than this describing noise.
For example, my 07 Camry had Plazmacluster ionized air purifier that will make mild crackling noise when operating, due to electric discharge. Totally normal.
Is it coming from inside the cabin?
From under the hood?
Can you open hood and hear it with all that running?
Where is fan blowing during this? If on any Windows position, AC WILL automatically turn on. That means, AC clutch will work.
1 - 2 of 2 Posts
