Tightened down valve cover without torque wrench on 96 5sfe real tight
In idle When accelerating to 2k it sounds normal weeeee, when get to 2.4k and above it sounds wooooooh
It needs a new timing belt and its tensioner and spring and idler , but was wondering if the valve cover could be contacting the valvetrain causing bounce, or if valves were floating, or this is sound of worn rings or crank bearing area play
