1 - 6 of 6 Posts
H
Guest
I need to know if a rebuilt engine from a 98 Camry can be used in a 87
Camry. also, the bushings need to be replaced. which bushing?, don't have
a clue.
Q
Guest
Discussion Starter #2
If you have enough money, I bet you can find someone to make it fit. And
there are bushings all over the place. I'm not quite sure what you're
talking about.
Q
Guest
talking about.
D
Guest
You'll have a much simpler time using the same engine type.
Not to say it is impossible, but the engines are clearly not the same.
The electronic engine controls are different.
Just guessing about bushings - would guess the bushings in the
suspension - front swing arm.
D
Guest
Here's an example.
Read about a guy, put a '97 engine into a '96.
There was no wire for the crank position sensor, and the car wouldn't
run without it.
1 - 6 of 6 Posts
