1 - 4 of 4 Posts
1984 toyota supra
Hey i got a 1984 supra celica and i just wanted to know if i could swap the engine with any newer celica engines cause the engine i got now is getting really weak and just wanted to know?.if you got anything please reply:)
84 and 89 Supra
Your most direct and documented swap is the 7mgte out of the mk3 turbo. You could be adventerous and try the 3sgte but it NOT be a fun project. Seriously though; it really depends on your budget. If you're just looking for something that's plug and play then locate a 6m from your local jap importer...just keep your 5m oil pan/pump and you're set to go.
Anything else (including the 7mgte) will require a lot more money/skill and time.
So saying that one wanted to swap their 5mge for the 7mgte, would that bolt to the stock tranny? What all will still be usable? I know the wiring harness is pretty much worthless so i'll need the 7mgte harness, and prolly the gagues. But does it bolt to 5mge motor mounts and tranny?
5M-GE
Physically, it should bolt up. All "M" blocks share the same bellhousing pattern. You may have other nitty-gritty things to contend with such as shifter position and driveshaft, which I'm not familiar with.
1 - 4 of 4 Posts
