1 - 7 of 7 Posts
2008 Toyota Camry LE
Does anyone have any idea what clips are suppose to be used for the engine under cover. Mine is damaged a little bit and was looking at replacing, but I keep finding all different types of clips.
Are you referring to clips for the splash shields? If so, this thread might help you out:
· Super Moderator
2020 Prius Prime Limited
What is the car themo? Not sure if there is a difference between the Gen 5 and the Gen 6. And like maestro asks, is that the plastic shield that is in two pieces?
· Super Moderator
Those are just 10mm bolts, not sure of the pitch and size but anything that will thread into there will work.
· Administrator
マズダスピード3
1 - 7 of 7 Posts
